30mm Hub centric wheel spacer size
Hi All,
I am looking to get some 30mm spacers guys. What size a`m i looking at in diameter and centre?
Hubcentric, 5x114.2 (5x114 is the same) with a 64.1 bore.
Thank you sir. Any opinion on 30mm spacers? I have quite an aggressive camber so the tyres should fit within the arches.
It's quite big on an EP3, 3cm further out each side. Are you just trying to get the wheels out in line with the arches?
Yes that is exactly what i am going for. I just think it give the car a much more aggressive stance. :)
They aren't hubcentric, no lip on the centre hole and yes the bore is too big.
These are what you want: http://www.ebay.co.uk/itm/H-R-60656...heels_tyre_Trims_Trims_ET&hash=item1c3f94f107
Picture is wrong but those are the size you are after, part # 6065641
Another couple of links:
http://www.amazon.co.uk/6065641-Wheel-Spacers-60/dp/B00BWUQI76
http://www.performancealloys.com/spacer-details.aspx?ID=905
Don't scrimp and go cheap on spacers. They will be the only thing holding your wheel on at the end of the day.
As always, very helpful Loxy. Thanks again! Not cheap are they!? :)
