Project EP3
Hi everyone my names Richie. I'm from Co. Wicklow in Ireland and said i'd join to get some information on Honda's and thoughts along my build and read along other peoples builds and any teething issues along the way.
I drive a 2007 Accord Type S for a daily driver and an EP3 Type R for a weekend / blow off steam car.
I've only got the Type S about a week so since getting this i just added wind deflectors as otherwise its all good and fits my comfort levels for a daily driver. I don't want to take the comfort or fuel economy out of it.
The EP3 i have about a year and I've done some work & upgrades already to this one with plenty more along the way as this car looks to have been neglected mechanically over the years. Car stank of smoke and was covered in road grease and grime so first things first was a 2 day valet on the car. Both my wife and I got stuck into getting it somewhat clean and presentable.
I've to date done the following:
  • Upgraded Honda Clutch master cylinder
  • Hardrace Engine mounts
  • Hardrace front bushings
  • Hardrace balljoints
  • Hardrace inner tie rods
  • Hardrace outer tie rods
  • Hardrace front anti rollbar bushes
  • Hardrace front anti rollbar drop links
  • GReddy Oil Temp, Oil Pressure & Water Temp Digital/analogue gauges
  • Oil filter sandwich plate with Oil temperature and pressure sensors
  • Blox Air filter (K&N one that was on it when i bought it was way past it)
  • Carbon Fibre air intake cover
  • New Excedy Clutch 3 piece kit and input shaft bushing
  • New gearbox oil seals
  • Gearbox oil change with OEM Honda gearbox oil
  • Engine Oil & Coolant Flush
  • New Motul 5w30 Fully synthetic motor oil
  • OEM Honda oil filter
  • New Iridium tip spark plugs
  • New OEM Honda knock sensor
  • New OEM Honda Lambda Sensor
  • New Coolant temperature sensor
  • Uniroyal Rainsport 5's all round
  • Rocker cover resprayed to wrinkle red
  • Coilpack cover wrapped in carbon effect vinyl
  • Removed the rear bumper to clean up behind it, cleaned up surface rust from rear crashbar, rust treated, primed in zinc primer and sprayed black.
The EP3 had a K&N Typhoon air filter system when i bought it and coilovers which i will be removing to fit standard suspensions back onto it with lowering springs.
I'm sure there's loads more but that's all i can think of at the minute. Still a good bit of work to do on it mainly to the rear end suspension setup, some bodywork to clean it up and then a gearbox rebuild as my 4th gear syncro has started to give trouble.
I've had a few Honda's in my past, an EM1 coupe, an EJ9 and a CL Accord. Nothing along the EP3 lines thou.
A before and after of the rear crash bar and cleanup behind the bumper
Engine bay needed some loving too.
  • Respray of the rocker cover in wrinkle red
  • Carbon fibre intake manifold cover
  • Coilpack cover wrapped in carbon effect Vinyl
  • General wash down under the engine bay
A new air filter was installed after this picture was taken.
Where did you get the rocker cover done
A girl on one of the Honda facebook pages done it for me. She done the Rocker cover and coilpack cover wrapping.
A year on from when i got it done now and it still looks as good as the day i put it on.
