15-02-2019, 01:41 PM
#231
The Following User Says Thank You to NYA For This Useful Post:
20-02-2019, 12:15 PM
#232
B16
I bought some more carbon
About £1k's worth.
Also having a chat with spooner about rocker covers. Shall be sorting that out when I'm back from my next trip aboard (leaving on Friday for a month). It should be looking dapper for JAE if I can get that dash installed.
Decided to go for the carbon rather than the ally doors, despite the weight saving being significantly less. Because carbon. Doors next.
The Following 4 Users Say Thank You to Hazz For This Useful Post:
Chris. (20-02-2019), ewaaj (22-02-2019), NYA (20-02-2019), TarmacNymph (20-02-2019)
17-03-2019, 07:23 AM
#233
B16
Well rocker cover is off the cards... the b18cR I’ve purchased has a mint one
In less positive news... gearbox is FUBAR. That final drive I bought is pony. Stevie will be having the box off for a 4th time.
I might just buy a Kaaz one and throw the Watson’s one in the bin. Doubt I’ll ever get a refund on it. Ratio isn’t as favourable but at least it’ll be lapped in (won’t whine) and you never know... might actually fit the gearbox properly.
For anyone interested the Watson’s is a 3.7. Kaaz do a 4.05 & the OEM was a 4.4.
17-03-2019, 09:00 AM
#234
Just made of weak material or poor fitment?
17-03-2019, 10:41 AM
#235
B16
Poor fitment by the sounds of it. They’re known to whine due not not being lapped together but it has also caused neutral to have drive and also caused 2nd gear to be difficult to engage. Stevie has had it on the lathe and given it a tickle. Forward gears now sorted but reverse isn’t playing ball. I’ve not had an answer on whether or not neutral is still wanting to move the car.
PITA. I can’t just go and buy another make of FD either, they don’t make them for an s9b. I’ll need a whole new box. There’s a recon s80 on eBay but it’s not cheap.
17-03-2019, 06:34 PM
#236
Ballache. I don't envy that.
17-03-2019, 07:28 PM
#237
Founder
I've got a Kaaz diff in my FD2 which came highly recommended, not sure if that's any help or not but at least you know the brand is a good one.
The Following User Says Thank You to Chris. For This Useful Post:
31-03-2019, 12:40 PM
#238
B16
Update:
Still at grinspeed. Stevie is sourcing a 4.05 from mfactory for it and a long 5th gear. Should roughly equal the revs from the current (****) 3.7FD and OEM 5th and give a bit of punch back into 1-4th.
The B18CR is in transit to grinspeed. Still undecided on ECU but it’s between a DTA and a Hondata S300. I’m leaning towards the S300, even though I don’t need half the functionality. Tried and tested and all that.
It’s also had some work done on the front end, new double springs & new top arms. Apparently the springs knock a little over big bumps but the spring rate is much better so I’ll live with that.
Hopefully get that done in the next month. Then it’s back home for a carbon dash install with my custom gauges & my carbon weezle goodies.
The Following 6 Users Say Thank You to Hazz For This Useful Post:
dweezle (31-03-2019), jimbodeeni (01-04-2019), Loxy (31-03-2019), NYA (31-03-2019), SK-R (31-03-2019), TarmacNymph (31-03-2019)
13-04-2019, 10:20 AM
#239
B16
Carbon has started to arrive. Binnacle and switch panel from my two part dash
Went to have a look at the motor at grinspeed during the week too. Looks mint
Spoke to EFI about tuning and ECU’s. He said go Hondata S300, so I shall be ordering that in the next couple weeks.
Slow progress but progress nonetheless.
Edit: I also updated OP with current spec (or spec to be at least)
UKDM y0!
dweezle (13-04-2019), jimbodeeni (15-04-2019), NYA (13-04-2019), TarmacNymph (13-04-2019)
17-04-2019, 05:40 PM
#240
B16
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
