225 45 17 tyres
Just fitted the above - does the pressure differ from using 205 45 17 please?
Also, the drivers side front tyre rubs on the plastic wheel arch when braking around a bend and go over a bump. It did not do this with 205's.:(
You've gone wider and since profile is a percentage of the width, you've also increased the rolling radius and so you've increased size in two aspects.
http://www.willtheyfit.com/index.ph...ct2=45&wheel_size=17&wheel_width=7&offset2=45
If you had of gone 225/40/17 it would have been closer to OEM, but most people only go 215/40/17 because of the extra tyre with. Your speedo will now also be under-reading.
If it's catching, you'll eventually expose the cord. Spacers would help, as long as it doesn't then touch the outer arch.
