EP3 Flashy's CG EP3 premier
Changed the transmission fluid last weekend and the shift is better. Rear superpro arb bushes on, front to do.
Concentrating on a few things before power, will do the valve clearance myself, will also replace the front lower arm bushes myself and stick some new drop links on. Will check out the ball joints and track rod ends too.
Superpro Arb bushes done front and back, got these to fit next weekend :D
Cleaned yesterday.
Had to order some new bolts for one of the mounts, easy enough to swap over though. I should have checked the bolts before taking the old mount off :D
Switched the pcv valve as the car was using a little more oil than I'm used to, was a bit oily around the valve...
JDM RARB and Meyle HD droplinks put on today, took me a little longer than expected due to the seized nuts on the lower arm connection. Well impressed with the handling improvement. More to come.
I changed mine in the summer with the exact same kit and I think it feels much better round corners. Great mod to do. Mine took me a day and a half, all bolts and nuts were seized and had to cut off all drop links in the end plus a bolt snapped off on the ARB bracket so had to tap and die it, nightmare but definitely worth while doing.
Here's what is left of the original nuts, and a pic of the drop links and JDM arb
Just bought an ITG Maxogen and an M2 silenced b pipe. Will be selling my Tegiwa M induction kit and scuttle scoop
The scuttle scoop also includes the half scuttle itself so it is a straight swap. Everything is included including the silicon intake hose! Do you have a max spend in mind? I need to weigh up the pros and cons of selling etc
I can provide a standard scuttle to replace your cut one if you need it?
Think the last one I saw was on eBay for around £230 chap.
Think I'll be sticking it on for more than that, has the heatshield too. Brand new around £400 for the lot and they are popular when it comes to selling. Won't be for a few weeks as I'm currently recovering from a dislocated shoulder operation.
Ouch! See if there's any for sale and use them as a guide price chap. Once you've decided a price drop me a message and we'll see where we are at.
On the subject of trying to price things up, anyone know what a Fujitsubo RM01a back box is worth? Excellent used condition as can be seen in pic...
Got the ITG today to replace my Tegiwa M
OK, one has popped up on eBay for £295 collected. No mention of intake pipe, heatshield or breather pipe.
Yeah just seen that, quite local to me too but I can't travel currently and as you say, no mention of the other bits.
