TD Pro Race 1.2 / Rota Force Specs
Hi everyone, looking at getting some new wheels for my ep3. Have seen the TD pro race 1.2 and the Rota Force that i like the look of. I'm lowered 30mm, which spec of fitment would be best. Would both fit without needing arch work? I'm running 215/45/17 AD08r's
7x17 et45 TD
7x17 et40 TD
or
7.5x17 et45 Rota
Cheers :)
I'm running 215 45 17 ad08r on Rota boost wheels 17x7.5 et45. They sit fine, I'm not lowered but take a look...
Not directly comparable as I'm running a slightly different size tyre, I have AD08R's in 215/40 on TD 1.2s that are 7.5x17 et37. Lowered a reasonable amount on coilovers and doesn't rub. I'll get a pic on my way out of work later.
Hey all - hi @flashy :)
I'm just about to put an order in for some pro race 1.2 - 17 x 7.5j et35
They'll fit won't they and clear brakes etc? I'm currently using evo 7s and they're ok on 17 x8j et38 - 215 45 17 AD08r
Not on that one :D
Is your FN2 lowered? I had 18x8 et45 Pro race 1.2 on my lowered Fn2 and it was OK, although yours will stick out an extra 4mm but that's the wheels not the tyres. I had 225s compared to your 215s so probably the same.
Not on that one :D
Only on 15mm prolines mate.
Ive seen some folk use evo rims on their fns and a mate uses evo fitment pro race in et38 for his, but not sure what width
15mm drop. 18x8 et45, compared to stock 18x7.5 et55. I had oem brakes so no issue. They sat 4mm further from the strut and 16mm further out.
So the lower the offset the more it'll clear the brakes? Should be ok in 35 then as I use 15/20 mm spacers ony oem fn2 wheels with no probs. Extra 5mm on front but then a smaller wheel diameter and tyre width but higher profile
They're mainly for the ep so thats the most concern
Just don't see many folk using the et35. They're all 38 or 45, but often 8j, I'm only going 7.5j
