Hi all,
Having a bit of an issue here with my brakes, and it seems to be a strange one…
So first thing in a morning, after the car (ep3 type R) has sat maybe 12/13 hours, my brake pedal goes to the floor, if I pump the brakes with the engine on or off, it starts to build resistance and then the brakes work fine, getting progressively better the more the brakes are pressed.
With the engine off if I pump the brakes the pedal goes hard, when starting the car the pedal depresses so I’m guessing this rules out any vacuum issue?
There is no fluid being lost, I’ve checked this every day for the past week, marking a line on the reservoir just to be sure, no leaks.
This only happens if the car has sat for a while, for example if I drive to work and they’re good, I’m at work 8 hours then drive home, the brakes are fine.
Discs and pads are fine, fluid was replaced around 3k miles ago. This isn’t something that has really got progressively worse, I left the car while I was on holiday for a week then noticed it, now it is a daily occurrence if I leave the car for more than 12 hours.
Any ideas? I haven’t done anything so far, I’m going to give the brakes a bleed and see if that makes a difference but I don’t think it will, I think I have an issue with the MC/Servo, but im not sure?
Cheers,
Ell
Cheers,
Ell
