Ep3 rebuild
You're a braver man than I am to tackle this on your EP, but you're doing a grand job looking at the pics. Mine needs it doing but I don't have the space, or a barn to hand. The rust will finally kill it in a few months.
Looking good so far EP3irish. Thanks for sharing - this is my kind of build thread and am already looking forward to seeing your updates as you progress.:smt023
Sanding down calipers using wire wheel.
Sent from my SM-G965F using Tapatalk
After couple of coats of hammerite. Still need to touch a couple of bits up as you can see
Arch sanded down with wire wheel using grinder and drill attachment for smaller areas. Also masked up for painting.
Getting there slowly. Hopefully get both front arches and engine bay finished shortly. Plan to sand the rest of the engine bay and the other arch. Then rust preventer, primer, base and clear.
Then sand and paint remaining suspension components ie hubs, struts, arb etc.
Bit more done today. Sanded down using grinder wire wheel and 320grit paper by hand for the hard to reach places.
