Hello all,
I'm new to the forums here (well posting that is) - I was hoping someone would be able to give me some advice or point me in the right direction for alloys / tyres??
Previously i have always bought tyres and wheel packages which come with fitting packs... However they didn't have the alloys i wanted in stock this time so i went ahead and bought some separately.
I bought these alloys: TEAM DYNAMICS PRO RACE 1.3 ALLOY WHEEL 18"
http://www.tegiwaimports.com/team-dynamics-pro-race-1-3-alloy-wheel-18-civic-type-r-fk2-15.html
Width: 8.5"
Offset: ET45
PCD: 5x120
CB: 64.1mm
Weight: 10.5kg
Colour: Gloss Black
From what i understand is spigot rings / valves / bolts are needed if you're going to buy the tyre & alloys separately.
The Center Bore for the fk2 is : 64.1 mm which matches the alloy so i assume no spigot rings are needed?
And i could use the same OEM bolts with the new alloys too?
I'm also looking to place these tyres (Dunlop SP Winter Sport 5 225/40 R18 ) on the alloys...
I think Loxy had this size on for his Pro Dynamics 1.2 for the same alloy size which i read a while back.
Any help or advice would be appreciated.
Thanks !
Width: 8.5"
Offset: ET45
PCD: 5x120
CB: 64.1mm
Weight: 10.5kg
Colour: Gloss Black
Thanks !
