FK8 Rear fender inserts
Guys n gals,
I’ve searched high and low, but can’t find the thread regarding carbon inserts for the gaps just behind the rear doors.
Anybody help?
Trev
Sorry, it’s the nearest I could get.
Mine is getting clear PPF on those next month along with some other bits. Hopefully it will alleviate some of the damage caused by gravel rash...:)
I don't see the point in using carbon fibre other than for looks, fair enough if on the car when new (Not sure the OEM stuff is much lighter), not that much difference in weight if anything in aftermarket stuff, quality is sometimes questionable. Best use a wrap. You also need to ppf it so it doesn't get chipped.
It's FRP which will require painting and blending, then pending on quality it may require a bit of trimming then bonding
