Hi
I have a dc2 which has had a turbo conversion. Which I have recently just purchased. Don’t really know a lot about the car.
The problem is I will drive fine for 10mins then it won’t rev past 3500rpm. Sometimes restarting can sort the issue for 10mins. Other times you need to let it cool.
Anyway I changed the tps and now it won’t rev past 2000rpm. And when u hit 2k it just dies back down to idle. The throttle does nothing until it drops down to idle.
In neutral the car will rev to redline. Also will rev to red line With the clutch depressed in gear.
Any one had similar problems.
Any help would be much appreciated
Also it’s running a hondata s300 Ecu.
