FK8 Wire Gauge Size
usually written on the wire (or at least it is when you actually buy it). failing that, watts/volts=amps, so you know what current wire you need.
I'll see if I can find it on the wire in the light tomorrow. Just meant is there a standard wire gauge that's used for wiring headlights as I need to use a splice to link 2 together. Want to make sure the splice I order is correct for the thickness
Sent from my ELE-L09 using Tapatalk
