EP3 P0141 EML On after replacing sensor
The Eml has always been on my car since I bought it, thought it was due to it having a decat fitted.
Just fitted the original manifold and cat, replaced both O2 Sensors and when I went to get the EML turned off with a OBD scanner, it went off for a few moments and came back on
The error code I got was
P0141 - O2 Sensor Heater Circuit Bank 1 Sensor 2
Anybody got this after changing the sensor? One I fitted was NGK brand
Is it the standard 4-1 EP3 manifold or a DC5 4-2-1 manifold you replaced the decat with?
I had to fit an O2 spacer when i fitted the DC5 manifold as the EML would come on due to the better flowing cat on the DC5. Never seen it again since i fitted the O2 spacer after the Cat.
It was just the standard 4-1 manifold that I fitted back on it.
Unless it was a Honda OEM sensor you’re likely to get the code come back on. The cheap ones either don’t cure it or don’t last at all.
