Waxoyl cavity advice
Hi, I going to Waxoyl inside the chassis of my EP3, what did you use, Waxoyl or Testroseal or another?
I don't have a compressor in my garage, so I have to use a hand pump type (as shown below with a long flexible hose to insert) what do you use?, would you recommend it?, I was going to use Waxoyl but there are reviews that say they need to thin it down with white spirit because of the weather temperature.
Do you have an tips if you've already done it?
Hand Pumps available
https://www.amazon.co.uk/Waxoyl-614...585658172&sprefix=waxoyl+spray,aps,153&sr=8-2
https://www.ebay.co.uk/itm/Sealey-S...021342&hash=item56720a1540:g:i7MAAOSweW5VAW~B
https://www.zoro.co.uk/shop/automot...ates&cjevent=7b17da99734a11ea814a00980a18050c
I used bilt hamber dynax cavity stuff. Gets really good reviews and seems to last a long time in cavities. Comes in an aerosol and goes quite far. It has a long tube nozzle with loads of holes so gives a good all over coating.
Definitely worth looking into.
Norv, how many aerosol's did you use on your car?
I was thinking two?
I used 2 to do the inner sills cavities. That was a decent coating. Then used Por15 for the external stuff.
Should do the job nicely.
