I bought foglights for my 05 EP3 a while ago and finally found the time to try to fit them. I used this guide so far:
https://type-r-owners.co.uk/forums/...g-fogs-and-bumper-removal-on-facelift-version
Problem is, the wiring on my foglight-kit seems to be completely different. While I found the brown plug shown in step 11 behind my battery, there is nothing coming from the fog lights that would fit on that - instead I got the excact same plug on the cables of the foglights again. Also I cant figure out where the brown plug from step 10 is - does not seem to be there.
It almost looks like the cables that came with the fog lights are meant to be put in the car aaaaaall the way from the foglights to the switch and fusebox, but I have no clue how to get inside and how to fit anything.
I bought the kit from a guy called Rehan Rashid on facebook, maybe someone has the same kit and can help me out here.
Maybe I should mention that I'm from germany, so my EP3 is LHD and has the stock Xenon headlight along with headlight-washers.
On the picture you can see all the connectors pretty clearly. The green one is for the switch, the brown one is the exact same one that can be found behind the battery. The visible part of the cable is connected to the another part (that goes to the foglights) via a white connector.
