FN2 Heat shield problem..
Just happened today really, noticed a slight vibration coming from the back end when setting off in 1st, going round corner slowly and changing into second then it disappears till I slow down. Looked under the rear passenger side, looks like a one side of a heat shield resting on the exhaust. It looks like its vibrated of the fitting but only on one side. Theirs a hole on the heat shield where the fitting located but the fitting still in the car underside im pressuming.
Is this easy to replace and how is it fitted on.
Its fine now, I put search in google and read it on an old post on another forum..seems like a common issue that happens. Will look at popping it down to my mates to tac weld it on if I cant fix it back on.
