Will these fit without needing the arches rolled 17x8 30ET
Hello
did some looking around but could not get a definitive answer
will these wheels fit my ep3
I have a 30mm lower springs
want to know if they will fit my ep3
they are
5x114.3
17x8J
ET 30
The Tyres they come with are 215/45/17 87W ADVAN AD80R's
They'll be fine on the hub side but will stick out 27mm over oem. Get a measure out and see what that would do.
The ad08 is quite a wide tyre on the shoulder, I think an offset of et38 would be about as far as you could go.
Thanks for your input :)
I have the car in pieces at the moment
has anyone fitted this exact wheel and tyre size combo
if It rubs on the arches guess I will have to roll them
The 215 tyre will be a little stretched. I had 17 x 7.5 Rotas with 215/45 r17 ado8r and they were fine. A lot run the evo enkei which are 17x8 but they are offset et38 and a great fit. The et30 I suspect will rub, not 100% sure.
