K-PRO VS UNICHIP *UPDATE PAGE 2*
K-PRO & UNICHIP
Well folks this topic may cause a bit of a stir round the forums but I will try and put down
the full story as it happened. I may add right from the start that it is not my intention to slag one product or company but what you may find from this post makes for some interesting reading. I will give you the facts about what was done and at the end of the post give you my views as the car owner and having owned both systems. Grab a beer (or cold drink) smokes if you have them and read on.
I bought a 2002 CTR and started to modify it. Comptech Icebox. Magnex back box, HKS earthing kit and Hondata inlet manifold gasket. I then went for a Dastek Unichip and had it mapped to my car at Dastek in Dalgety Bay.
After a short time I decided to fit a Hondata K-Pro ecu. Zportec arranged to have this mapped to my car (with the same mods) at TDI North (system r).I was very pleased with the K-pro and took my car to a rolling road day at Dastek and had a power run done. To my surprise and shock the car made the same power as it had done with the Unichip fitted. To say I was pissed off would be an understatement and me being me thought there was some skullduggery going on. Ok the two power runs where not conducted on the same day but surely the K-pro should give more?
When I fitted the K-pro ecu I kept my original ecu so I was in a position where I had a standard ecu and a Unichip mapped to it and also a K-pro ecu. After discussions with Dastek they where up for a test on the same day with the same dyno to see what the real story was.
I must say that from the outset Dastek where extremely professional and we both came up with what we felt was the best way to run the test to try and take out any discrepancies in the results. It was agreed that the car would be strapped down and no adjustments would be made to the fixing of the car for the duration of the test. Two runs would be conducted with each ecu and only me and two independent witnesses would know which ecu was in the car for each power run. Paul from Dastek would run the car for each test and he would be out of the dyno cell while the ecu changes where done. The computer screen showing the results from each run was also obscured from Paul’s view and he was told just to take the car to the limiter for each run.
Before each run was conducted I measured inlet manifold temp and gearbox temp using a very accurate laser temperature gun. It was extremely difficult to get these readings identical for each run but I definitely got them as close as was humanly possible in my opinion. Barometric pressure was also recorded and dyno cell temp was also monitored through the whole test to keep things as consistent as possible. The car actually ran for very short periods relative to the time spent in the dyno cell so temperature build up was all but nil. Across the runs the average Cell temp was 25.4c and Barometric pressure an average of 1016.
All the power figures are at the flywheel. Dasteks dynos calculate power loss on the run down. Some may want to know the power at the wheels but for the purpose of this test it isn’t really important as all the runs are on the same dyno so for comparisons sake it’s perfectly ok.
We ran the ecu in this order.
1. K-pro
2. Standard
3. Unichip
But I will give you the results starting from standard and then Unichip / K-pro.
My immobilizer function on my K-pro is disabled so the flashing key on the instrument binnacle was covered up so as not to give the game away when that ecu was in place. We pulled fuse six before each two runs to reset the ecu just to take any memory out of the equation. This probably wasn’t essential but once again it was a way of keeping everything consistent. The car was filled with Optimax and the test began.
First two runs with Standard ecu.
GEARBOX TEMP: RUN 3. 40c / RUN 4. 44c
INLET MAN TEMP:RUN 3. 30c / RUN 4. 31c
POWER OUTPUT: RUN 3. 204BHP / RUN 4. 204BHP
Two runs with Unichip overlaid with standard.
GEARBOX TEMP: RUN 5. 46c / RUN 6. 45c
INLET MAN TEMP: RUN 5. 33c / RUN 6. 30c
POWER OUTPUT: RUN 5. 210BHP / RUN 6. 209BHP
Two runs with K-pro overlaid with standard
GEARBOX TEMP: RUN 1. 43c / RUN 2. 43c
INLET MAN TEMP: RUN 1. 33c / RUN 2. 30c
POWER OUTPUT: RUN 1. 212BHP / RUN 2. 210BHP
Can now show Unichip overlaid with K-pro so you can see any difference between the two.
Ok so the answer that everyone is looking for is this! Yes the K-pro does give you more bhp in comparison with the Unichip. The difference is small but it’s a difference none the less. Although the power curve with the Unichip does look smoother. Looking at the torque graphs the K-pro again makes more peak torque figures but look again and see that the Unichip seems to gain more at certain parts of the rev range but lose out at others. Obviously these comments could also be applied to the K-pro. The biggest gain just after 5500rpm is most certainly down to the lowered V-tec engagement point with the K-pro a definite benefit of this system.
So now to my personal comments about the two systems as the owner of both.
My initial reaction when I had the Unichip fitted was that I personally felt I had not got the best from it. I posted about it at the time but after seeing the two systems running side by side my thoughts at that time where most definitely unfounded. I did have one hot start problem with the Unichip but it never happened again and was down to me not waiting long enough between the dash lights coming on and starting the car. Fuel economy with both systems in my experience has shown that the K-pro does give more mpg than the standard ecu and that the Unichip did give me less than standard. This might not be very important to a lot of people especially as we are looking for a faster car so fuel economy maybe goes out the window. Although it does give another aspect to think about when choosing either system. I would also add that this in no way means you would get the same results on mpg it’s just my experience with both systems.
I still have the K-pro on my car and maybe that says it all really but there has been so much misinformation regarding the two systems with a few comments basically saying that the Unichip does not work. I think we can safely say from this test that it does and what has been posted here is a way of showing the facts so you can make your own mind up. Obviously if your supercharging your car then K-pro is essential and even a manifold in my opinion would benefit from K-pro more than a Unichip but for what mods the majority of us do to our CTR’s (mild exhaust mods/induction) I think this test gives you all an idea of what to expect.
Big big respect has to go to Dastek for allowing this test(at there expense) and after speaking at length to Gerry and Paul they really are petrol heads at heart you really have to take your hat off to them for putting all there cards on the table.
Thanks also to TDI north (system r).I have always been very happy with there service and would have no hesitation in recommending Paul and his company to anyone.
Many thanks to Zportec.com. Responsible for maintaining and developing my car to my exact needs. Their attention to detail in all the work carried out on my car still continues to impress me.
This post in its entirety can be found along with additional video footage of the runs at www.zportec.com
And so that would appear to be the end of this post! But is it?
Now what do you think would happen if we put the K-pro ecu in the car and then attached the Unichip to it and live mapped the two together????????????????
Well after twenty minutes of live mapping here are the results.
GEARBOX TEMP: RUN 7. 44c / RUN 8. 46c
INLET MAN TEMP:RUN 7. 30c / RUN 8. 31c
POWER OUTPUT: RUN 7. 212BHP / RUN 8. 214BHP
The bhp graph is very close but does really show what a powerful tool live mapping is! A definite advantage to the Unichip system. The Hybrid ecu just edging the K-pro in almost the entire rev range.
The torque graph shows similar results. The gains the Hybrid ecu made are even better on the torque graph and really do once again underline how very powerful a tool live mapping is.
So that’s it folks hope you all enjoyed the post as I certainly spent enough time on it.
I have done my best to be impartial and give you all the facts and thanks for your time.
Si
Nice one! Very well written 8)
Just out of interest, how much does a unichip knock off your 1/4mile or 0-60?
A very informative and well written post imo. Nice one Si. :smt023 8)
As a relative newbie to ecu mods and mapping, its really good to have people like yourself, (and the tuners involved,) taking the time to explain your findings to us.
Cheers to all involved. 8) 8)
Excellent post.
Gives other owners out there a more informative background in which to make a choice.
:smt023 Very good post
People have been getting some very good results for The unichip on the S2000. Because there is No Hondata makes a cheaper viable alternative to some of the top end ECU's like AEM ect
Quality post. It will help me make a more informed decision when I tune my ctr.
One question I do have is that I was told that the kpro takes into account the cam profiles of the k20 engine whereas the unichip didn't, therefore longetivity of the engine tuned by kpro would be better. Is this the case or is there more to this?
Thanks for the positive feedback guys 8)
Yes the K-Pro can alter cam angles which the Unichip cant. I still recon the K-pro is the best for the CTR especially as you go further in your mods. But this test does show you have an option with the Unichip to get good gains for a bit less money.
Without a doubt K Pro is the best choice you could make as regards the ECU of a CTR, but, the Unichip may yet prove tempting for some. Watch this space I suspect....
As a cheap option the Unichip looks like it is a winner. How long did you have it on your car may I ask? Just I've read many threads with people having problems with it...
I think it was mainly the earlier ones that caused problems, I heard that the later ones were much better :?: And to some degree I suspect it would depend on how good the tuner is.
Definately a mod I'll be considering after xmas! :D
Had it fitted to my car for 6 months Chris on and off. I did have one hot start problem(as mentioned in my post)but it didnt happen again. I know some folks have had more problems than this but this is my experiance with the Unichip.
Yeah that's fair enough. Wouldn't mind hearing from someone who's had one on their car for a year possibly longer. We know safely now that the KPro is safe to use due to the number of users, but the Unichip isn't so well proved.
Not knocking you at all mate, nor the product, but I'm sure people who are possibly thinking about this mod may want to know from those who have had it for an extensive period of time.
Hmm, just wondering, the graph above with the Unichip attached to the KPro, I'm just wondering what would happen if you asked Paul at TDI to run a more aggressive map that is more drag/track orientated then road and then see the comparisons. Seems like the Unichip (I'm going from you saying about the economy) just runs a very aggressive map.
Thanks for the post anyway, brilliant write up.
It's always possible to make more power but is it safe?
You tune a car first for fuelling then for optimum ignition. At max ignition you will also get knocking which isnt safe so you back it off 2-3'. Your not at the maximum the car can make but you are safe.
I know what I would rather have. :wink:
Also remember if you pay for a "generic" map and have it safe tuned it may be cheaper than a "custom" tune but you wont ever get the best out of the setup.
Not nocking Dastek as I have had one with excellent results on a previous car. On a ctr they are fine with simple mods but as soon as you add more complex mods like a manifold, supercharger, cams etc you need to be able to control vtec point and cam angles.
Would agree with you there tp. More power is always available but sometimes its not safe. Paul was very open about this and would rather i came back to him for further tuning with my engine intact than hit the headlines with a "look how much power this car is making"but for how long type deal.
I will mod my car further and this is why the K-pro is the best option for me and even the little things like being able to raise your idle speed(with the uprated engine mounts) make the K-pro in my opinion that much better a system.
As a continuation of this test Paul from TDI contacted me through my local tuner who maintain my car (zportec.com) with an invitation to come to his workshop and conduct a similar test as we had carried out at Dastek. I felt this was a very good idea as it would give everyone a chance to see the results from both companies perspective.
Right from the outset Paul was extremely open and mentioned he was impressed with the test we had carried out. He was sure the K-pro should not have made any less power than the Unichip and really could not understand why the Hybrid in particular had managed to extract the biggest gains from his original tune. But there it was in black and white so in his words he couldn’t really argue with it.
He would like to run the hybrid ecu and then the K-pro ecu on his rollers and then see if he could match the power of the hybrid with some additional tuning to the K-pro. This was his main aim in the test as apposed to showing the gains from a standard car to K-pro as I think this information is already available.
The car would be strapped down and no adjustments made throughout the duration of the test. The car was run with the bonnet closed as in Paul’s opinion this is how the car is driven and is the only way to show the true figures you will be driving with on the road.
I expressed concern over this as I felt the temperature build up would be a factor in the results for each run. Paul suggested that the Hybrid should go first so if there was any benefit to be had then he would give it to the hybrid setup. We also agreed to wait five minutes between runs with the engine off and the dyno fan on to keep temperatures down. Two runs where conducted with each setup and the lowest figures recorded are the ones you will be looking at. Fuse six was once again pulled between each setup. An independent witness was also present to keep everything fair and it was not Paul that would run the car on the dyno.
So now to the test! The figures once again are recorded at the flywheel as Paul’s dyno can also calculate power loss on the run down and although you will see differences in the figures recorded between Dastek and TDI the differences between ecu setups are what we are looking for here.
Hybrid ECU
Initial comments from Paul where that power is certainly ok although the graph does look rather bumpy and there where a few points that the car was running rather lean in his opinion.
K-pro ECU
Power curve looks smoother with this tune and power as you can see is also considerably higher.
Two tunes overlaid together so you can see any differences between the two.
This is the graph that will certainly raise a few eyebrows. The original test at Dastek showed that the Hybrid ecu produced more power and torque than the K-pro but going on these results on Paul’s rolling road you can clearly see this is not the case by quite some margin.
I had mentioned to one of the independent witness after the test at Dastek that the hybrid ecu had felt slower in driving conditions and I have had two other people drive the car and they both had similar feelings. These dyno plots would appear to confirm my thoughts.
It was unfortunate that we still didn’t have the standard ecu with the Unichip mapped to it to compare as that is what the original test was all about. But if the K-pro in this test can beat the hybrid by the margin it did then im sure you could conclude that the difference would be higher with a standard ecu/Unichip configuration.
Paul was then up for tuning my car from scratch with the K-pro to see if there was anymore power to come from the K-pro. My initial tune from TDI was an hours dyno time but looking at the graph Paul was unsure how much more power was available as im sure you will agree 225.3BHP and 170.4 lbft are very impressive for a car with very basic mods. Nevertheless Paul would spend the remainder of the day tuning the car.
After countless dyno pulls and a quick visit to the pub for my lunch here are the results overlaid with the original part tune.
My initial reaction was one of total shock and we conducted four dyno runs just to check the results. Each run showed the same power give or take a couple of horsepower. The gains netted between a full and part tune are certainly there but the part tune power does really show how good Paul’s database of maps are for customers who decide on the part tune option.
Going for a full or part tune in my opinion should always be a decision that the customer should be allowed to make and when you weigh up the costs £411.25 for a full tune against what I spent originally £76.37 you really have to ask yourself does the extra gained justify the expense? If the car is never going to be modified further then in my opinion a full tune is best but if like me you will be adding mods at a later date then the part tuning that Paul offers is saving the customer a rather large part of there money. And hats off to him for offering this service.
Paul I think was very impressed by the results from my car with the minimal mods it has but was keen to point out that these gains are not the norm as some cars with full exhausts and better induction sometimes don’t make this much power.
Big big thanks to Paul and the crew (thanks for all the coffees) for conducting this test at there expense and it certainly was a long day for us all but I did drive home with a bigger grin on my face than when I arrived.
Once again I hope the post makes for a good read and im sure there will be a few comments about the results.
Fooking excellent write up 8) :wink:
Hats off to Paul for offering to do the comparison as well.
He's one of the best and nicest people I've come across and it shows in his attitude towards his customers and his work efforts.
Great post, I'm very happy with my Tdi map! Can't fault it at all, it's spot on IMO, wouldn't take my CTR anywhere else now! 8)
Would have to agree with you there CTR. It was a great day down at TDI and would thank Paul once again. 8)
Most excellent post, thanks to all concerned for their efforts. I think this should be made a sticky, hands up who agree....
