Torque Specifications quick reference thread. Everyone needs this...well almost everyone.
Suspension
Suspension
- Tire Lug Nuts 80 ft/lbs
Front: - 12mm top nut (1) 33ft/lbs
- 10mm Strut tower Flange Bolts (3) 33 ft/lbs
- 16mm damper pinch bolts (2) 115ft/lbs
- 10mm tie rod nut (1) 32ft/lbs
- brake hose bracket (1) 16ft/lbs
- wheel sensor harness bracket (1) 7.2ft/lbs
- Axle nut 134 ft/lbs
Rear - 10mm top nut 22ft/lbs
- 10mm strut tower top nuts (2) 43ft/lbs
- 12mm damper bottom bolt 45ft/lbs
Rear Camber Arm - 12mm outter bolt 43ft/lbs
- 12mm inner bolt (2) 43ft/lbs
- 8mm wheel sensor harness bracket 16ft/lbs
Rear Tie Bar - 12mm inner bolt 43ft/lbs
- Front
- 10mm top end link bolt [to bar] 28ft/lbs
- 10mm bottom end link bolt [to car] 29ft/lbs
- 10mm bracket bolt (2) 29ft/lbs
Rear - 10mm top end link bolt [to bar] 28ft/lbs
- 8mm bracket bolt (2) 16ft/lbs
- Upper Pass Engine mount Flange Nut 40 ft/lbs
- Rear Engine Mount 43 ft/lbs
- Front Engine Mount 47 ft/lbs
- Transmission Engine Mount 40 ft/lbs
- 14mm subframe bolts (4) 76ft/lbs
- Oil Drain Plug: 33ft*lbs
- Oil filter: 8.7ft*lbs
- Drain plug: 29ft*lbs
- Filler plug: 33ft*lbs
- 10mm Header Bolts/Nuts 33 ft/lbs
- 8mm Header to Downpipe spring nut 16 ft/lbs
- 10mm exhaust manifold bracket bolts 33ft/lbs
- O2 sensors 33ft/lbs
- Cat to midpipe nut 25 ft/lbs
- Midpipe to Axel back spring nut 16 ft/lbs
