EP3 Torque Specifications
Torque Specifications quick reference thread. Everyone needs this...well almost everyone.
Suspension
  • Tire Lug Nuts 80 ft/lbs
    Front:
  • 12mm top nut (1) 33ft/lbs
  • 10mm Strut tower Flange Bolts (3) 33 ft/lbs
  • 16mm damper pinch bolts (2) 115ft/lbs
  • 10mm tie rod nut (1) 32ft/lbs
  • brake hose bracket (1) 16ft/lbs
  • wheel sensor harness bracket (1) 7.2ft/lbs
  • Axle nut 134 ft/lbs
    Rear
  • 10mm top nut 22ft/lbs
  • 10mm strut tower top nuts (2) 43ft/lbs
  • 12mm damper bottom bolt 45ft/lbs
    Rear Camber Arm
  • 12mm outter bolt 43ft/lbs
  • 12mm inner bolt (2) 43ft/lbs
  • 8mm wheel sensor harness bracket 16ft/lbs
    Rear Tie Bar
  • 12mm inner bolt 43ft/lbs
Sway Bars
  • Front
  • 10mm top end link bolt [to bar] 28ft/lbs
  • 10mm bottom end link bolt [to car] 29ft/lbs
  • 10mm bracket bolt (2) 29ft/lbs
    Rear
  • 8mm bracket bolt (2) 16ft/lbs
Engine
  • Upper Pass Engine mount Flange Nut 40 ft/lbs
  • Rear Engine Mount 43 ft/lbs
  • Front Engine Mount 47 ft/lbs
  • Transmission Engine Mount 40 ft/lbs
  • 14mm subframe bolts (4) 76ft/lbs
  • Oil Drain Plug: 33ft*lbs
  • Oil filter: 8.7ft*lbs
Transmission
  • Drain plug: 29ft*lbs
  • Filler plug: 33ft*lbs
Exhaust
  • 10mm Header Bolts/Nuts 33 ft/lbs
  • 8mm Header to Downpipe spring nut 16 ft/lbs
  • 10mm exhaust manifold bracket bolts 33ft/lbs
  • O2 sensors 33ft/lbs
  • Cat to midpipe nut 25 ft/lbs
  • Midpipe to Axel back spring nut 16 ft/lbs
What about Brembo Brakes - more specifically the caliper/carrier when changing out brake pads?
Bump. Just found this. Good reference. :smt023
