Honda Bulb Sizes/Types
I've been meaning to put together a list of bulb sizes/types for a while now seeing it's a very commonly asked question.
EDIT 07/01/10: Updated with Jazz GD1/GD6 and Integra DC5 Bulbs
There are a few lights I'm not sure of, so please help me populate the list if you know them! And please advise if there are any errors. Cheers! :)
Civic Type-R
EK9
EP3 Pre-Facelift
Headlights: H4 (Main and Dipped) Dual Filament
Front Position Light: 501 / 194 / T10
Front Indicator: Offset Pin BAU15S
Front Fog Lights: H11
Side Repeater: 501 / 194 / T10
Interior Lights: 31mm Festoon 269
Interior Boot: 501 / 194 / T10
Rear Fog Light: 382 / P21W / BA15S (Single Filament)
Rear Indicators: Offset Pin BAU15S
Rear Reversing Lights: 382 / P21W
Brake Lights: 380 / P21-5W (Dual Filament)
Centre Brake Light: 501 / 194 / T10
Rear Number Plate: 501 / 194 / T10
EP3 Facelift
Headlights: H1 (Dipped), HB3 (Main)
Front Indicator: T20
Rear Reversing Lights: W2 / 921 / 912 / T15
FN2
Front Indicator: PY21W / 7507 / BAU15s 21w
Low "Dipped" Beam (Halogen): H7 55w
Low "Dipped" Beam (HID): D2R 35w
High "Full" Beam (Halogen/HID): H1 55w
Position "Side" Light: T10 / W5W / 501 5w
Front Fog light: H11 55w
Side (Mirror) Indicator: Factory LED N/A
Glove box: T5 / 17 2w
Vanity Mirror: Vanity, Fuse bulb 2w
Front Dome: T10 / W5W / 501 5w
Courtesy Light: Factory LED N/A
Footwell (if fitted): Factory LED N/A
Centre Dome: 31mm Festoon 3w
Cargo Light: T10 / W5W / 501 5w
Rear Indicator: T20 / W21W / 7440 21w
Brake/Rear Position(2006~2007): T20 / W21/5W / 7443 / 21w/5w
Rear Position(2008~2011): T10 / W5W / 501 5w
Centre Brake: Factory LED N/A
Licence Plate: T10 / W5W / 501 5w
Reverse Light: T15 / W16W / 921 9w
Rear Fog Light: T20 / W21W / 7440 21w
FD2
Integra Type-R
DC2 Pre-98 UK
DC2 Pre-98 JDM
DC2 >98 UK
DC2 >98 JDM
DC5 Pre-Facelift
Headlights: D2R (HID - Dipped), H1 (Halogen - Main)
Front Indicator: Unknown
Side Repeater: Unknown
Rear Fog Light: Retrofit
Rear Indicators: Unknown
Rear Reversing Lights: Unknown
Brake Lights: HBU580 / R580 (Dual Filament)
Centre Brake Light: Unknown
Rear Number Plate: 501 / 194 / T10​
DC5 Facelift
Accord Type-R
NSX Type-R
Other Hondas
S2000
NSX
Accord
CRV
FRV
Prelude
Jazz/Fit
GD1/GD6 Pre-Facelift
Front Indicator: Offset Pin BAU15S / 581 / PY21W
Rear Indicators: T20 / 582 / W21W
Rear Reversing Lights: T20 / 582 / W21W
GD1/GD6 Facelift
I'm having trouble finding the reverse bulb type for EP3 facelift, I can't find a website with the w2 / 912 / 921 fitment :(
Ok they are also known as the T15 fitment. Yes they are the wedge type.
i need new headlight bulbs for the dc5, can someone post me a link to where i can buy them?
i cant seem to find bulbs for an itr on autobulbs direct. cheers
many thanks for the info much appreciated and saved loads of hassle searching
You're very welcome. Glad it's been of use to others.
Shame there are a few gaps which hopefully owners of those cars can confirm what they are.
Hi all,
I drive a facelight EP3 Type-R. Does anyone know if the 2 interior bulbs at the front near the windscreen are the same bulb as the interior light that comes on when you open the door?? Any help would be greatly appreciated.
Hi all,
Yes they are the same. Two in the front (map lights) and one in the rear.
HI, hope somebody can help me, I have a 2003 Integra Type R, one of my dipped headlight bulbs has gone, having removed it from the car it has a H7 bulb in which has been cut to fit? It does not have HID so what is the correct bulb that should be fitted is it a HB3? Thanks
are the DC5 dipped beam bulbs D2R for both pre and facelift models? i need new dipped beam bulb for my facelift but cant rely on your list to buy them besause you list a H1 bulb as the main beam for a facelift DC5 which is wrong, they have HB3 bulbs... anyone know for sure if the dip beam is the same on both models??
I'm confused.
On the HIDs4u website when u search Honda civic 01-05 it comes up with H4 size conversion kits? So will these fit or does it need to be H1 as it says above?
HIDs4U like a lot of sites, don't realise the EP3 has 2 versions with different bulbs. The data in the OP is correct
