EP3 FD2 Specifications.
Credit to fd2-owners.com
LeeH said:
The Japanese market Civic Type R (FD2) went on sale on the 30th March 2007. For the first time the JDM Civic is sold as a four door sedan rather than a three door hatchback.
The new Japanese model's engine output is higher than the European version's, with 222bhp (225 PS) being developed at 8,400rpm and 159lb ft (215 NM) of torque peaking at 6,100rpm (versus 198bhp at 7,800rpm and 142lb ft at 5,600rpm for the European model).
Model Type ....................................................ABA-FD2
Transmission.................................................. 6MT
Layout........................................................... FF
Seating Capacity............................................ 4
Dimensions & Weight
Length / Width / Height (mm).......................... 4,540 /1,770 / 1,430
Wheelbase (mm)............................................ 2,700
Tread Front/Rear (mm)................................... 1,505 / 1,515
Indoorsize Length/Width/Height (mm).............. 1,900 / 1,470 / 1,170
Weight (Kg)................................................... 1,270
Minimum Ground Clearance (mm)................... 135
Engine
Engine type.................................................... K20A
Engine........................................................... Watercooled L4 DOHC
Displacement (cc)........................................... 1998
Bore x Stroke (mm)........................................ 86.0 x 86.0
Compression Ratio........................................... 11.7
Fuel System..................................................... PGM-FI
Horsepower.................................................... (kW[PS]/rpm) 165 [225] / 8000
Torque........................................................... (Nm[Kgm]/rpm) 215 [21.9] / 6100
Drivetrain
Gear Ratio...................................................... 6MT
1st................................................................. 3.266
2nd ................................................................2.130
3rd................................................................ 1.517
4th................................................................ 1.147
5th................................................................ 0.921
6th................................................................ 0.738
Reverse......................................................... 3.583
Final Gear Ratio.............................................. 5.062
Suspension Front/Rear.................................... McPherson Strut / Double Wishbone
Brake Front/Rear............................................ Ventilated Discs / Discs
Tire Front....................................................... 225 / 40R18
Tire Rear........................................................ 225 / 40R18
Fuel Capacity (liter)......................................... 50.0
Exterior Exclusive front bumper & black painted front grille
Exclusive rear bumper & black painted rear diffuser
Exclusive front spoiler & streak
Dark chrome grille bar & headlights sub reflector
Exclusive HONDA emblems & TYPE R emblem
Exclusive hood & front fenders
Exclusive red engine headcover
Aluminum bumper beam
Aluminum clear turn lamps
Exclusive side sill garnishes
Black painted large size rear spoiler
Dark smoked rear combination lamps
Dark chrome Civic emblem
Exclusive exhaust pipe finisher
Colored electric door mirrors
Half shade windshield
Rear window deffogger
Mechanical Exclusive hard setting suspension
Exclusive POTENZA RE070 (225/40R18) tires.
Exclusive 18inches alloy wheels (18x7.5)
Exclusive black wheel nuts
Front BREMBO aluminum 4 pot calipers
Torque sensitive Helical LSD
Large size disc brakes (F : 320mm R : 282mm)
Front brake air intake ducts & air intake plates
Exclusive setting ABS
Exclusive setting EBD
Exclusive DBW (drive by wire)
Power steering
Interior Honda R spec seats
Exclusive 3spoke leather wrapped steering wheel
Exclusive steering wheel emblem
Exclusive multi flex meter
i-VTEC/REV indicator
Aluminum shift knob
Short stroke sport shift
Metal sports pedals & foot rest
Engine starter button
Exclusive black metallic panel & power window switch panel
Exclusive aluminum emblem with serial number
Exclusive aluminum emblem on side step garnish
Exclusive black metallic door handle
Exclusive design key
Safety Driver & passenger i-SRS air bags
HID headlights with auto leveling
LHD high mounted stop lamp
Clutch start system
Comfortable Full auto air conditioner
Speed sensitive auto door lock
Keyless entry unlock
Security aram
Immobilizer
Power window
Power window switch lamp
Powered door lock
Also read this link
http://webferret.search.com/click?w...ec.net/Engines/FD2K20AR/index.html,,altavista
