Pull the stalk for the washer jets and nothing comes out, whilst doing this pull the bonnet release lever and if the water starts coming out, you have the same issue I have just had.
This picture shows you where the cables go. Just the one push clip at either side and the one in the middle and the scuttle comes off.
Basically it was #25 that was fouling on mine. It somehow gets trapped between the windscreen scuttle and the bulkhead.
You need to tuck the tubing underneath the scuttle mounting holes on the bulkhead so it doesn't get trapped as you put the scuttle back on.
Problem solved.
Problem solved.
