Home
Results 1 to 6 of 6
Thread: Buying guide/check list for the EP3 Civic Type R
  1. #1
    The Dave's Avatar
    Join Date
    Mar 2011
    Location
    Stoke-on-Trent
    Posts
    228
    Default Buying guide/check list for the EP3 Civic Type R
    I was speaking to head honcho Chris and he asked me to post this up here, it's info I collated from this forum and a few others when I was looking to buy my EP3 Type R, so all in all a handy checklist to print out to take with you when viewing cars so you don't get too hung up on the excitement of a new motor and have something nearby to prompt you to check the usual stuff.
    Hope it's of use to some of you
    Engine & Drivetrain:
    Waterpump and belts seem ok?
    Check oil (& cap), coolant, other fluids for levels/condition
    Which oil is in the car ran on and is the oil level ok? Shows it's kept an eye on. 5w/40 fully synth is ideal
    Blue smoke at the back? Any smoke up front?
    VTEC engages properly?
    Noises; tappets and lifters etc. Not to worry too much, could just need valve clearances setting. Bartering point!
    Gearbox, notchy/crunchy?
    2nd gear works ok? No jumping out of any gear?
    Clutch feels ok - no juddering? No slipping? No release bearing noise?
    Listen for whining from Gearbox
    Engine and gearbox mounts, much rocking of engine?
    Noises/rattles/vibrations/leaks
    Easy to start?
    Temp when idling, check fan kicks in
    Suspension:
    Steering rack recall work
    Steering rack noisy, notchy, sticky, dry spots, creaky/clicky
    Tramlining? Any excessive pulling left or right?
    Tracking – check tyre wear and how wheels sit
    Wishbones, bushes etc – does the car sit level?
    Steering doesn’t feel loose indicating worn ball joints, track rod ends etc?
    Brakes, Wheels & Tyres:
    Check condition and wear of brakes and tyres
    What are wheels like, corrosion, buckles etc
    What brand of tyres, do they match? Good sign of how well the owner cares for the car.
    Check rear tyre wear
    No brake juddering?
    Electrics:
    Whirring when ignition on – front headlight adjustment noise?
    Lights, heaters, anything worth trying etc, windows, interior lights, mirrors, aircon if applicable
    Keyfobs to test locks, key in the door also and in the boot
    Interior:
    Condition of steering wheel, plastics, seats, door cards
    Carpet condition, check not wet, same for A/B/C pillars and boot
    Window rattles and good performance going up and down incase of faulty window mech
    Check all electrics inside work – lights, windows, wipers, stalks, switches etc
    Seats feel solid, not rocky etc, same for door cards if leant on hard
    Exterior:
    Rust in general and on the arches, hinges, (boot hinges/door hinges/bonnet hinges)
    Dents/Scratches/Stone chips
    Paint issues – laquer, fading, swirls etc, headlight fading/blotchy, side skirts loose?
    Check under the cills and jacking points for damage, under bumpers/skirts also for scuffs/cracks
    Docs, History, Other:
    All keys & 2 alarm fobs?
    All history – manuals, service books (check stamps), receipts, MOT cert(s), tax discs, V5 docs, Type R Leather Folder
    Check HPI clear
    Locking wheel nut key!
    History on major services, 50k service, 75k service
    75k service details? Timing chain checks and tensioner checks, valve clearance, tappets, lifters full on service; belts, filters, fluids, hinges etc
    Hope that helps a few of you!
    Cheers,
    Dave
    Some more:
    Quote Originally Posted by mad_allan
    CTR Buyers Guide
    Ok, so I often see posts asking for buying tips on the CTR but we don't have a complete buyers guide we can all add too.
    So I decided to make this one.
    What should I look out for
    Steering Rack
    This was the most common and costly issue. There is a huge thread here
    The most common way to spot this is to centre the steering wheel and let go, it will pull to the right more often than not if it hasn't been replaced under warranty.
    2nd Gear
    The next most common issue is the 2nd gear crunching. This is very common, especially when the car is cold. To spot this, you would need to make sure the car
    hasn't been warmed up when you get there. If it has, you won't notice the problem so much until you have bought it and start up the next day!
    See this thread for more info
    Idle Control Valve
    This is also a known issue. Once the car is warmed up, it feels like it will want to stall all the time. It normally just needs adjusting, any local garage / speciallist will be able to fix this.
    Heatshield
    The heatshield rattle can be annoying if you experience it. There is no definitive fix, either tighten the bolts or do what others have and remove it.
    Corroding Alloys
    Almost all of the alloys will corrode at some point. If you have a Honda warranty, get them replaced. The paint lacquer will start to peel off, the alloys from Honda cost around 250 each!
    Noisy Valves (Tappets)
    You may hear a tappety sound, more prevalent when the car is cold but also heard once it is warmed up. This should be done on the 75k service, it's just valve clearences and can be done at any time
    Rocker Cover Paint
    Under the bonnet, the Rocker Cover may have paint flaking away. It's nothing to worry about, just makes the engine bay look untidy!
    Door Handles
    The interior door handles often lose paint (the silver handle and surround on the inside). Again, this is a known issue and can be rectified with some vauxhall silver paint from your local Halfords
    Alarm going off
    There is also a known issue with the alarm constantly sounding. This is when water seeks it's way through the ariel and allows moisture in. Take the car back into the dealer and get them to sort it out of you have a warranty.
    If no warranty, still take it to a dealer!
    Window Rattle
    Nothing you can do about this one. When driving with the window a little way down, it will rattle and annoy you
    Please feel free to add to this, I will keep the post updated
  2. The Following 5 Users Say Thank You to The Dave For This Useful Post:
    almas09 (16-04-2014), Chris. (06-05-2012), EP3 Dave (23-01-2013), EP3 GER (03-08-2013), Loxy (06-05-2012)
  3. #2
    Founder Chris.'s Avatar
    Join Date
    Aug 2005
    Location
    On track
    Posts
    52,019
    Default
    It's worth noting that the car has a tendency to tramline, made worse by some tyres, especially on uneven roads.
    Thanks for posting.
  4. #3
    The Dave's Avatar
    Join Date
    Mar 2011
    Location
    Stoke-on-Trent
    Posts
    228
    Default
    I think I'm gonna buy another, nothing is quite as good an all round practical motor for me and feels as nice to drive as a good old EP3 for me currently!
    Obviously I made the initial checklist, but can anyone think of anything to add to mine plus the one below in the OP?
    Thanks guys.
  5. #4
    mrhaz's Avatar
    Join Date
    Feb 2014
    Location
    Birmingham
    Posts
    538
    Default
    Question from the first post anybody know how long the warranty covers for corroding alloys and steering rack???
  6. #5
    Site Treasurer Loxy's Avatar
    Join Date
    Jan 2009
    Location
    Lancs
    Posts
    29,094
    Default
    Three years or 60,000 miles whichever came first.
    Long gone on an EP3 unless you're buying from a garage that gives you warranty on purchase but check the small print as some things aren't always covered.
  7. #6
    mrhaz's Avatar
    Join Date
    Feb 2014
    Location
    Birmingham
    Posts
    538
    Default
    I wouldn't think mines going to be covered I recently bought it private thanks for advice.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
