Wheel help???
What does this mean? I have no clue with wheels!
Thanks in advance!
2008 NHB CTR R-13399 :)
Yeah ok sorry...
Fronts- 16 X 7, 105 pcd, with a approximate positive offset of around 30mm and a centre of 60mm
Rears-16 X 9. 105 pcd, with a approximate with a negative offset of around 10mm and a centre of 60mm.
What does what mean????
They are the size specifications for the wheels.
105 is the PCD in mm.
16 x 7 means they are 16" wheels, 7" wide.
+30 Offset
and a Centrebore size of 60mm
For the record FN2 alloys are
PCD 5x114
Et55
18x7 1/2J
Edited width as per correction later in the thread. ;)
OK
well would wheels that are the following fit, and if they would would they stick out of the arches by loads?
PCD 114
18 x 8 (front) and 18 x 8.5 (rear)
and offset 30mm (front) and 33mm (rear)
Thanks in advance!
No they wouldn't fit.
My alloys are 55 offset with 15mm spacers so effectively 40 offset with 1.5 deg camber and they are virtually flush with the arches.
30 offset would physically go on, but they 100% definitely would rub on the arches and would be a borderline MOT failure as they aren't allowed to protrude from the wheel arch.
I thought FN2's were 18x7.5
They are, I didn't see the half hiding away. :lol:
http://www.hondaoriginalparts.com/h...ck_01=17SMR701&block_02=B__1800&block_03=9966
Part #20
DISK, ALUMINIUM WHEEL (18X7 1/2J) (HAYES LEMMERZ)
