Home
Page 488 of 504 FirstFirst ... 388438478484485486487488489490491492498 ... LastLast
Results 4,871 to 4,880 of 5038
Thread: Generic FK2 Civic Type R discussion
  1. #4871
    veehexx's Avatar
    Join Date
    Jul 2018
    Posts
    334
    Default
    did he get it back dotty?
    anyone aware of a rhd pedal spacer for fk2?
    FK2R Mods: Remus cat-back, Remus Responder, K&N Panel Filter, DBA 4000t3 discs, PBS ProRace Pads, HEL oil cooler, TDI-North Intercooler, HCTR Brake Cooling Ducts || Audio: stock + Audison APBX10DS sub || Summer: OE 19" wheels, 255/35r19 PS4S & Cup2
  2. #4872
    D3ano's Avatar
    Join Date
    May 2013
    Location
    Suffolk
    Posts
    166
    Default
    Middle right indicator is oil pressure Iím guessing guys? Donít know if itís because I havenít drove the car in 4-5 days but Iíve noticed that going up and down like a goodín tonight and sure it wasnít doing that before, seems to increase with throttle depression and was going up to about 5.4 which Iím sure I havenít seen before... unless Iím going mad, anyone able to shed some light?
  3. #4873
    dweezle's Avatar
    Join Date
    Nov 2011
    Posts
    2,286
    Default
    You will see higher pressure on a cold engine and on depression, once the oil has done a few passes and warmed up it will start to drop.
    I topped the oil up week before last and panicked when I saw the pressure rising to 5.6, (thought I'd overfilled) sigh of relief when it dropped
    I was the same as yourself and started doubting it, I thought I knew my regular pressures but for some unknown reason it's gone, I'm always in +R and fluctuating pressures is normal, so I would say normal
  4. The Following User Says Thank You to dweezle For This Useful Post:
    D3ano (19-02-2019)
  5. #4874
    D3ano's Avatar
    Join Date
    May 2013
    Location
    Suffolk
    Posts
    166
    Default
    Cheers bud! Moment of panic, normally Iíd be more certain of whatís what but after 5 days not in it I started to second guess myself, I should be giving it a proper run out at the end of the week and not just a 5 minute drive to the gym and back so will see how it behaves then!
  6. #4875
    RSmith1992FK2's Avatar
    Join Date
    Jul 2016
    Posts
    93
    Default
    What do you consider a normal oil pressure reading once engine etc is warmed up?
  7. #4876
    dweezle's Avatar
    Join Date
    Nov 2011
    Posts
    2,286
    Default
    Depends on driving styles, gears, and also temperatures,
    This morning on start up mine was 5.6-5.5, driving up the road it increased to 5.7-5.8, few miles in and it gradually dropped.
    I'm usually sat around 2000rpm in 5th or 6th and once warmed up I'm getting around 4.8-5.0 pending on the above conditions, on a fully warm engine on idle I'll see 1.2-1.4
  8. The Following User Says Thank You to dweezle For This Useful Post:
    RSmith1992FK2 (20-02-2019)
  9. #4877
  10. The Following User Says Thank You to Loxy For This Useful Post:
    Chris. (26-02-2019)
  11. #4878
    veehexx's Avatar
    Join Date
    Jul 2018
    Posts
    334
    Default
    ...almost unflappable on track...
    someone been smoking AND found a catX for £17k.... or driving it like miss daisy.
  12. #4879
    D3ano's Avatar
    Join Date
    May 2013
    Location
    Suffolk
    Posts
    166
    Default Generic FK2 Civic Type R Discussion
    Not that mine or myself have ever seen a track to know I donít really pay much mind to whatcars opinions on performance cars myself... after some of the things Iíve heard about the golf Rís brakes make me think surely the FK should be ahead of it on that basis.... surely itís the looks that have got it in the position
  13. #4880
    Founder Chris.'s Avatar
    Join Date
    Aug 2005
    Location
    On track
    Posts
    53,473
Posting Permissions
  • You may not post replies
  • You may not edit your posts
