I was going to buy a Rear Progress 24MM ARB part number 62.0103 for a 2004 EP3 Type R. The seller told me that according to his data the 04 Civic SI uses part 62.1006 which is 22mm. He told me that the 02-03 SI uses the same bar as the RSX but the 04 was different.
Has anyone fitted a 24MM Progress ARB on a 2004 Type R? Could it be because the Si use different anti roll bars from the type r?
And does the DC5 ARB fit on a 2004 EP3 if you change the bushings?
