will 5x114 alloys fit honda
No they'll fit.
You need to check the centre bore too. Honda are 64.1 usually. Spot on is great, bigger is fine but you'll need spigot rings to eliminate the gap, smaller is a no no unless you want to start grinding out the centre of the wheel to make them fit.
stock offset is et45. what you will need on aftermarket wheels will depend on the width you go for. the wider you go the lower offset you will want so as they clear the suspension parts etc but to wide and to low offset and you will need arch work.
Ok cheers i was thinking of either going for 8/17 or 8/18 what offset would i need? And will 225/40/18 tyres be ok?
