Helo i am new here... I'm having difficulties in rectify of my honda civic fd2 type R which are having some electrical problems.. 1. When insert a car key into the ignition key, "beep" or chime sound appear then after 10 beep sounds its gone.. 2. Then i start the engine, the door indicator, I notice flickering...then I shut the door, I swicth on the headlight, the dashlight keeps on and off.. 3. When the speed reach 15km/h , the speed sensitive auto lock door is not functioning... 4. I switch on the aircon, there is a unusual sound coming from the fan condensor.. All these problems coming only after I switch on engine... For ur information, i check already the error code.. It shows 9 codes.. Code 1: B1008 MICU lost communication with gauge control module (A/T message) Code 2: B1011 MICU lost communication with Gauge Control module (VSP/** message) Code 3: B1905 Immobillizer unit lost communication with MICU (door lock switch message) Code 4: B1906 Immobilizer unit lost communication with Gauge control module (A/T message) Code 5: B1205 Climate Control Unit lost communication with gauge control module (VSP/** message) code 6: B1206 Climate Control Unit lost communication with gauge control module (coolant temp) Code 7: B1207 Climate ControlUnit lost communication with Gauge Control Module (illumination message) Code 8: B1225 An open in the in-car temperature sensor circuit. Code 9: B1241 A problem in the driver's blower motor circuit... Can anyone of here rectify of my car's problem?? Any help would appreciate...
