So been a little busy doing a few things and sorting out the drop links.
Unfortunately had a ball ache getting them removed, and managed to damage the front LCA while me and the old man were trying to remove them, so managed to obtain a pair that are in much better condition anyway to replace them both.
So I got these while I was at it, so it will tighten things up and the front nicely...
However upon the mechanic going to fit them along with the LCA's it was found some things were missing.
I called up Tegiwa where they were purchased from to be told at first they use the existing ones. However when speaking to the mechanic and being informed they were all part of the bush, I was being fobbed off. So another call to Tegiwa and I was told to send a photo of the things I had received, luckily I took this one.
To cut a long story short they have sent me the missing metal sleeves so they can be fitted, but unfortunately they are still yet to be fitted, so all that has been done so far are the drop links all around and the replacement LCA, so will need to book it in again to have the other LCA fitted and the bushes.
Also managed to refurbish the centre caps, so resprayed them and fitted new red H's and clear coated them.
Also did some cleaning in readiness for something that was coming up and also for JAE.
So the tedious job of cleaning in between the rear badges.
I noticed the rear Type R badge the paint was coming away, so a cheap easy fix for now was to replace it with a vinyl R that is exactly the same size and fitted perfectly.
Will do for now but will replace the badge at some point along with the H badge as it is starting to go a bit now, but didn't fancy removing them at the moment.
