Yes the k100 will bypass the 2nd o2 sensor and the light won't be on. The light is only used to monitor catalyst efficiency anyway, yours won't have one so won't be needed. I now run a wideband AFR gauge from the 2nd o2 sensor slot, which is always good to keep an eye on the afr but not really needed as the map will still retain knock detection etc.
Who are you planning to use to do the mapping on it?
Sweet, was looking to get few gauges later on so will look into the wideband AFR (what ones do you have).
For the mapping I am planning to use Jessie for J.Cal. Did want to use TDi but it's a very long drive away from me.
