Still in warranty? (Not that means anything with Honda)
Has the relay been checked, was common on the previous model
Relay was revised across all Honda platforms once the previous issue was identified. It won't be that.
That being said, it is in the engine bay fuse box.
The revised part is by Mitsuba, the one prone to moisture failure was made by Omron.
Do you usually have the air con off? Ideally it should be on whenever you drive the car.
