We have the Stoptech 330mm BBK on our track car, it's amazing over the standard front set up!
Stoptechs are amazing
I currently have D2's which are nowhere near as good (but vastly better than OEM still).
I wanted to revive this thread last year when I had similar questions but wasn’t brave enough lol
I can give my own experience if you like.
I went with Brembo calipers off the newer model Megane RS. I got them from Freaky Parts. They look great and stop very well. I was slightly dubious about the rears being out of balance but there was no obvious issue I experienced with mine. The way it was explained to me is that with a FWD hatch, when you brake hard the rear gets light. Improving brake force to the rear could if anything increase instability. Better to introduce more force at the front where the majority of the weight is being transferred.
I had 345 2 piece rotors with mine. Probably overkill if I’m honest and if I had the choice again would probably go 324mm to save some unsprung weight
Use of the original rotor with a more capable monoblock 4 pot is exactly the philosophy Spoon went with for their kit so I don’t see why these wouldn’t be a good option for the money. For street use and track days they’d be good I’m sure.
I run the megane kit. I like that the calipers are easy to source as are the discs (350z or slightly cheaper Morano) which gives a fair bit of choice to pads and discs.
So far I haven't had any fade or issues at all. The carbotech pads I run have help up well on track, if a bit noisy and dusty for the road.
All in all I'm really happy with the brakes.
Sent from my HD1913 using Tapatalk
I run the same...
https://i.ibb.co/2W3nLRK/Brembo1.jpg[IMG][/QUOTE]
Interesting.
Are you both just running standard rears?
Interesting.
Yes standard rears with no problems on road & track...
