Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Registered users are encouraged to enable MFA/2FA to add an aditional layer of security to their account. More information can be found here: https://www.ncsc.gov.uk/collection/top-tips-for-staying-secure-online/activate-2-step-verification-on-your-email
Does any body have a guide on how to change the window rubber runner for the front window? Mine has split and its flapping about stupidly while driving and getting on my nerves, thanks Craig
If I'm reading it right, there is are bolts at the bottom, screw at the top, holding the sashes it in at the front and rear by the looks of it. Rubber is all one piece (5/10 on diagram) and should come off with the sashes removed.
I've not been in an EP3 for going on 4 years but it may be more obvious when you look at it.
The run channel seal is the pic above , yes thats the part you need
To replace it put window down then just pull top left corner down & out of the seal, then peel it out of the run channel then pull the seal up etc
Then to fit new 1 lube up the back of the seal & slide the seal down the window guide and then push it in the channel, repeat prosess for the other side of the window
Just changed the runner and it was pretty straight forward. Had to take the door card and window out to make things a bit easier, thanks for the info jizzy ����
My window keeps catching half way ish and flies back down. Again, think the rubber channels need replacing. Havent been able to fit my deflectors cause of this. Was it an easy job to do yourself? How much do the runners cost?
Yeah mate they was a piece of **** to fit, I bought it from Lings Honda think it was £55, to make it easier I took the door card off and window out, lubed up the outer edge and just slid it down into the channels, you'll understand when you're doing. It's pretty simple if I can do it
