Picked up my DC5 at the weekend and its been a great drive so far
Couple of things have popped up and im sure its probably nothing but just wanted to ask and make sure
When starting the car, bearing in mind its been freezing since i picked it up, it makes a small grinding noise for just a fraction of a second. Having read about it, sounds like its just the starter motor when cold? Just want to make sure its not related to my next issues
When you first start the car, again when its cold obviously and the engine is idleing slightly higher because of the temperature, when you disengage the clutch, the revs pickup slightly. Is this normal or again is it related to my last issue
The final one is similar to what i experienced in my S2k, but when the car is cold, changing into 2nd gear can be a real pain sometimes, so itll sometimes knock a little or even grind a bit. Is this an issue or completely normal? im thinking of adjusting the clutch slightly to see if it changes anything?
