As Mark has already said, just 2 drops of washing up liquid in 500ml of water in a spray bottle, very light spray over the panel before fitting will give the option to move the vinyl if needed, don't go over the top with the liquid, 2 drops is all you need or you will form a barrier between the paint/vinyl and it won't bond!
does the same apply with bonnet stripes? i bought a set of black bonnet stripes for my white fk2 from dream and they came with no instructions
they sit in the grooved lines on the bonnet and are super tack, which means no second chances if i try to apply them dry and make a mistake
so would the above recommendations for wet application be better?
its kinda giving me the fear to even attempt them as a dry fitting
thanks for the advice scotty44, will they stick as good wet as they would dry?
i presume they would just take longer to bond onto the paintwork
Use a plastic filler applicator, or something similar, to squeegee the excess water out from under the transfer. But do it lightly!
