Right so I've not had the car long and previous owner put newer style headlights in and made an arse of the wiring causing the car to have an "overvoltage" fault code. I found a melted wire removed it and replaced it. Cut all the junk wiring away and set it back to the standard Honda wires. Now I have no fault code and side lights, main beam work but no high beam. Relays are clicking when I switch on high beam but no power to the blue/red high beam wires. Fuses are good, relays are good. I'm thinking the fault is now in the fuse box it's self. Was wondering if anyone knows if the standard civic fuse box is the same and is there a circuit board or something in there that could be fried?
