Results 1 to 6 of 6
Thread: Ep3 brake disc sheilds on or off for track.
  1. #1
    Victor's Avatar
    Jan 2018
    Cornwall
    3
    Default Ep3 brake disc sheilds on or off for track.
    Just wondering what people thoughts were in removing these sheilds for better cooling on the track? Any down sides, cheers
    Sent from my SM-A520F using Tapatalk
  2. #2
    Lewisgame's Avatar
    Jun 2013
    947
    The shield is shaped to scoop air into the discs so Iím not so sure there would be any benefit.
  3. The Following User Says Thank You to Lewisgame For This Useful Post:
    Victor (12-05-2019)
  4. #3
    mike.h's Avatar
    Oct 2016
    Horsham, West Sussex
    1,650
    My worry with removal would be cooking the brake lines or your suspension, especially when on track. Heat shields are there to protect other things from the heat.
    Subaru Leone | EF Hatch | EG4 VTi | Rover 214Si | EK | BB5 | EP3 | EP3
  5. The Following User Says Thank You to mike.h For This Useful Post:
    Victor (12-05-2019)
  6. #4
    Norv's Avatar
    Aug 2014
    746
    Quote Originally Posted by mike.h View Post
    I've done a handful of track-days now with no dust shields. They're mainly there for preventing dirt and debris getting onto the discs/brakes.
    With the amount of air flow over them whe driving, the radiant heat would be minimal. Couple that with cool down laps and I struggle to see how anything would get hot enough with the amount of air gap there is between them.
    As an added note for example, new Vito vans don't come with any, and suffer from uneven pad wear due to the dirt etc adding even more friction to the inner pad. They don't have any additional heat shields fitted either.
    But as with any mods to a vehicle, you're changing something the manufacturer didn't intend, so always keep that in mind.
  7. #5
    mike.h's Avatar
    Oct 2016
    1,650
    Fair points Norv. I remember on my VTi in NZ I'd frequently end up with stones stuck between the shield and disc on gravel roads. Most. Annoying. Thing. Ever.
  8. #6
    karlos_91's Avatar
    May 2011
    Gloucester
    53
    If they arenít rotten and still in good condition then I would recommend keeping them on to assist blocking temps to other components
