Home
Results 1 to 9 of 9
Thread: Dc2 turbo help
  1. #1
    Pd9264's Avatar
    Join Date
    Jun 2019
    Posts
    8
    Default Dc2 turbo help
    Hi
    I have a dc2 which has had a turbo conversion. Which I have recently just purchased. Don’t really know a lot about the car.
    The problem is I will drive fine for 10mins then it won’t rev past 3500rpm. Sometimes restarting can sort the issue for 10mins. Other times you need to let it cool.
    Anyway I changed the tps and now it won’t rev past 2000rpm. And when u hit 2k it just dies back down to idle. The throttle does nothing until it drops down to idle.
    In neutral the car will rev to redline. Also will rev to red line With the clutch depressed in gear.
    Any one had similar problems.
    Any help would be much appreciated
    Also it’s running a hondata s300 Ecu.
  2. #2
    mike.h's Avatar
    Join Date
    Oct 2016
    Location
    Horsham, West Sussex
    Posts
    1,792
    Default
    No codes? Does the CEL light up briefly before you start the engine? You could try using SManager to see what kind of crazy map it's got installed - https://www.hondata.com/smanager
    Subaru Leone | EF Hatch | EG4 VTi | Rover 214Si | EK | BB5 | EP3 | EP3
  3. #3
    Pd9264's Avatar
    Join Date
    Jun 2019
    Posts
    8
    Default
    The cel does give only long flash and one short flash
  4. #4
    Pd9264's Avatar
    Join Date
    Jun 2019
    Posts
    8
    Default
    Just done some test on the TPS. And I have 5v on the yellow which is correct. But on the red and ground I have nothing. I have continuity across the 2 but no voltage. I’ve tried 2tps and both the same. When I open the throttle the continuity goes between the red and ground.
  5. #5
    mike.h's Avatar
    Join Date
    Oct 2016
    Location
    Posts
    1,792
    Default
    Quote Originally Posted by Pd9264 View Post
    Red and ground (chassis or battery terminal) you get 0 when untouched, does it change at all when you move the throttle-plate?
    How do you have this hooked up, that is - how have to arranged a connection to the TPS when it's also plugged into the wiring harness?
  6. #6
    Pd9264's Avatar
    Join Date
    Jun 2019
    Posts
    8
    Default
    Iv stripper the red cable a little bit just before it goes into the TPS. I’m getting ground from chassis. Battery in boot. All it’s giving me is continuity. No voltage at all. Even when the the throttle is opened. I have 5v going in on the yellow only. I’ve tried 2 different sensors. Ignition is on second position.
  7. #7
    Pd9264's Avatar
    Join Date
    Jun 2019
    Posts
    8
    Default
    It’s got to be the TPS I recon. As got 5v going in and I have a good ground. Just nothing coming ou on the redt. Thing is car was running before I switched the TPS. And when I fitted the old one back in it still won’t rev past 2k. Strange.
  8. #8
    Pd9264's Avatar
    Join Date
    Jun 2019
    Posts
    8
    Default
    Iv just ran smanager on car. Tps has 0% input. Going to order another tps and see what happens.
  9. #9
    Pd9264's Avatar
    Join Date
    Jun 2019
    Posts
    8
    Default
    It was the TPS. Fitted new one now ok.
  10. The Following 2 Users Say Thank You to Pd9264 For This Useful Post:
    Hazz (11-07-2019), mike.h (11-07-2019)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
