Home
Results 1 to 4 of 4
Thread: Help please steering issue
  1. #1
    mrhaz's Avatar
    Join Date
    Feb 2014
    Location
    Birmingham
    Posts
    536
    Default Help please steering issue
    Hi, I have 2005 ep3 I have had laser alignment done the suspension, ball joints and bushes etc have been checked out I have put 32psi all round in tyres but the steering is more heavy to the right than left but overall is stiff and heavy. I dont know why it's doing this but it does it temporary and then feels better other times. Any idea if this is a faulty eps motor or will the rack need greasing or changing i've had car for 6 years it's been great until recently I'm not even sure if it completely self centres or not as i sometimes have to straighten it in reverse and normal turns. All advice would be great Haz.
  2. #2
    Flashy's Avatar
    Join Date
    Aug 2017
    Location
    Swindon
    Posts
    1,846
    Default
    Have you checked the track rod ends too?
    R#3- Cosmic Grey 06 plate Prem EP3
    R#2- Nighthawk Black FN2 GT, R#1- Satin Silver Prem EP3
  3. #3
    mrhaz's Avatar
    Join Date
    Feb 2014
    Location
    Birmingham
    Posts
    536
    Default
    Quote Originally Posted by Flashy View Post
    Thanks for getting back and yes the car went in for m.o.t last week and had everything checked. I might take it back to honda hq for another check. Can the eps motor play up?
    Sent from my SM-J530F using Tapatalk
  4. #4
    mrhaz's Avatar
    Join Date
    Feb 2014
    Location
    Birmingham
    Posts
    536
    Default
    Update I checked the rack it seems fine there is no play anywhere in the rack or slider area. I will get track rod ends checked and for time being swapping front driver side tyre with rear tyre. Will take it back to the alignment again for them to check it. As it sometimes steers fine and other times becomes heavy I will most likely need to change the rack and slider by looks of it. 140 will cost to replace all is that about right?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
