FN2 Overheating at idle no fans
Hi all, was just wander if you could help, got an 07 fn2 that's just started overheating. If i go for a spin it gets up to temp fine and as long as keep moving the temp is spot on, how ever when I stop for more than 5 mins the temp creeps because the fans don't cut in, can be intermittent to. Think coolant sensor, relays, or bad connection? Is it a common fault? TIA
