Results 1 to 3 of 3
Thread: valve clearance question
  1. #1
    xantiaman's Avatar
    Nov 2019
    24
    Default valve clearance question
    hi all
    I am going to adjust my valve clearances tomorrow and never having done twin cam ones before i have a question..when the relevant piston is at tdc, are the inlet AND the exhaust done at the same time..i have watched various you tube vids and seen that the timing wheel marks are turned to 12 o'clock 3 o'clock 6 o'clock 9 o'clock and i've seen the inlets be checked and adjusted each time but never seen or heard that the exhausts be done at the same time..probably a stupid question to everybody in the know.
  2. #2
    Hamza Type R's Avatar
    Feb 2015
    Nottingham
    1,148
    Quote Originally Posted by xantiaman View Post
    hi all
    exact same time
    Premier Edition EP3 2005...Mercedes Benz C220D
  3. #3
    xantiaman's Avatar
    Nov 2019
    24
    thanks for the info Hamza Type R
