Intercooler and piping are obvious ones, but on some slightly smaller notes;
Could easily access the horns whilst there and change for Supertones with a plug and play adapter. (Can send links if you'd like!)
Could also remove the number plate plinth - Something I'd consider doing, and either fit a flush plate holder or attach the plate directly. (Perhaps even magnet mounts if you're feeling wild?)
TBH Only reason to replace IC is for a 400+ Tune or bling reasons - The larger IC's do look the part! I think lag depends on what you go for; Looking at what others report (Mostly Americans as usual!) some seem to give the same or slightly improved spool, whilst other intercoolers worsen things.
Silicone piping looks quite good; On a more practical note, the PRL set also includes a new throttle body coupler:- Some of the US users have reported cracking of the OE coupler, so perhaps a worthwhile preventative.
IMO, Avoid the hard piping like HKS - It looks great, but the engine vibrations should be isolated from the front of the car.
And these are the plug and play adapters:- Get the 4 pack, as I bought 2 originally and one was defective - QA Fail! (Some other reviewers have mentioned it too) - The ones that were working have been fine for the previous 13k+ Miles, So you shouldn't have any trouble.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
