70MM RBC INLET MANIFOLD help..!!!!!!
Yea it will restrict the air flow but you can run it like that as I did until I got a 70mm tb
i have 70mm skunk2 but i am afraid some people say skunk2 thotle body design problem and engine not working fine and after 15000km brokken insite its true.???
any one use skunk2 thotle body its be ok.??
What's this design problem? I have the skunk 2 70mm on mine and was unaware there is a problem?
You're over thinking things. The RBC will fit an OEM TB with an adaptor plate. e.g. https://www.tegiwaimports.com/index.php/tegiwa-70mm-rbc-adapter-plate.html
The urban myth is there is an issue with Skunk2 throttle bodies. This is pish.
It came from Skunk2 sending out early pre-production throttle bodies by accident years ago. Eveyone who got one by mistake received a refund or the correct throttle body. Buy one now and you'll have no issues whatsoever, unless there is a manufacturing fault etc.
