Hi chaps,
I've had an abs fat for a few months now. It's pretty intermittent and usually an ignition cycle will cure it once it's happened. Code is for osr sensor has open circuit. I've changed the sensor for a used genuine one, and the fault is the same.
A few weeks later the handbrake warning light started to go out and stay out, again it would come and go but has gone completely now. I've checked the switch and wiring that end. Even when earthed directly the light doesn't come on.
Both of these wiring faults point me to an internal wiring fault and I'm guessing the loom is rubbing somewhere and the hand brake like wire is broken and the abs wiring is rubbing occasionally.
Does anyone have any wiring diagrams? I'm after the pin outs for the abs control unit so I can monitor the resistance of the wiring while moving the loom about to hopefully flag up where the problem may be, and also the dash wiring so I can test the park brake warning light output.
Many thanks in advance
