Covered almost 300 miles in the new GT now. However returned to my car after work today, fired her up as usual and pulled away as usual.
The ABS light then came on in conjuction with the VSA light with the message check system in orange on the multi function computer display. It also had 2 symbols in oranage too that looked a bit like the speed alarm message.
Obviously I turned around parked up and switched off. Having looked at the handbook (which didn't seem to help) I called my local dealer. Guy just said sounds like an odd error and that if it happened again to take it to them to check out.
When i switched back on again everything had returned to normal. No errors, no messages and no error lights. Car drives just like normal and brakes are fine. Have used the car a reasonable amount tonight so switched off and switched on again a few times. Everything fine.
Should i take it to the dealer tomorrow just to check or if the errors haven't re-appered should i leave it be?
Could it be a co-incidence that it just so happens that my rear wheels seem to be much dirtier from brake dust and road dirt than the front ones. Is there a connection?
