AC Blowing Warm Air
Hello,
Whenever I turn the AC on during a hot day, it is warm air.
The only time I get cool air from the AC is at night.
Does anyone know why that may be the case?
Thanks,
Brandon
Most likely it needs re-gassing. However that will most likely due to either a leak in the system somewhere or simply that the AC is not used enough.
Excellent thank you Chris for your reply. I may just take it to Halfords or Kwik fit for a free air con check.
I don’t want to pay for a regas just for it to leak out again!
like Chris says.
What you are getting is probably ambient air being drawn in from outside.
Does the AC clutch engage/disengage as you switch AC on/off?
If the gas is too low it won't engage the compressor.
