I have been trying to sort a hesitation problem usually after i change gear the car puts down rather than picks up,also the idle is at about 780 rpm but seems a little rough as if it keeps missing all the time.Tried ecu reset and idle relearn but still the same
No DTC codes stored according to scanner
2004 model 30,000 miles.
Tried cleaning out the idle control valve,put everything back but may have created another problem as now the
Car seems to be running flat,seems like i have to work the car all the time just to keep up when driving around town.
Putting my foot down in 1st, 2nd,3rd gear very flat and then after a delay i can actually start to feel the car pulling but only a little bit at a time.The engine sounds to be straining.
Top end seems ok and Vtec kicking in ok when you eventually get there as the car seems sluggish.
Also noticed when slowing down the car surges usually just as i am about to touch the brake pedal and more noticeable when cold.
Any help,comments appreciated.
