Accord type R front calipers
Not a straight swap IIRC, pretty sure they don't need brackets fabricating but they need the discs too from memory.
Simon I'll be selling my DC5 Bremos soon if that's an option for you?
Can't seem to find anything on the net about it.
John is that to do with the thickness of the disc? The difference between the two are atr is 28mm thickness and 70mm bore and ep is 25mm and 64mm bore. Would the bore make a difference as they are same 5 stud pattern?
Chris cheers but probably not got that sort of spare cash at the moment. Can get these accord ones for £60 and if they don't fit the EP will sell them to Jamie for his tourer
Right found something on civinfo that says by using the Accord disks it is a straight swap apart from having to bend or remove the splash guard, Happy days :lol: Hoping there should be an improvement with the twin piston setup.
I think it's that the caliper sits in a different place and just doesn't like up with the Civic disc. Fine when you fit the Accord disc.
Simon, did u manage to try fitting the ATR calipers as i also have a set but unsure whether to fiddle around with them with new ATR discs to find out they don't or simply just buy a new set of CTR discs and pads :D
Hi mate , just got them stripped down at the moment so not had the chance to test fit yet but having done some research dont think its an issue fitting them apart from the splash guard which needs to be bent out the way or removed.
Finally fitted the Accord Type R front calipers apart from having to trim the splash/dust shield they are a straight swap. Good cheap upgrade, first impressions are very good need a track day now to fully test them.
Sent from my MotoE2(4G-LTE) using Tapatalk
Wow that looks good. Did u try aligning the callipers with the civic discs and confirm if they fit, or is the accord discs a must?
I didn't Johnny, but the accord ones are 3mm thicker and definitely needed. Cheap upgrade if you can get the calipers. I know you have some so get them fitted.
