I was wondering if some of you could cast your eye over the following, and give your thoughts.
I am looking to have the following supplied and fitted to my UKDM DC2
- Eibach Pro Kit Springs
- Rear adjustable camber arms
- Rear toe adjusters
- Aluminium front upper control arms, with camber and castor adjustment.
- Alignment set up with more aggresive 'fast road' settings
All of the above products are from Eibach/SPC. It will be TGM supplying and fitting the parts. I have used them before, and I am very happy with the service Tom gives.
Obviously the above is not cheap, and with all bits supplied, and labour including alignment set up, it will come in at around £900 max. inc. VAT. Tom did talk me through a couple of other options, opposed to using the front upper control arms, but I like the idea of a complete replacement part, without 'modifying' the stock set up.
I dont want coilovers, and I personally think the above list will be best for my needs, but I am willing to listen to anyone who has had similar work done, or used any of the above products. I am most keen to hear from anyone who has used the Eibach front upper control arms, as Tom speaks highly of them, but they are pricey!!
My only thoughts are maybe I could loose the rear toe adjusters, and make do with the stock adjustment.
Any help/advice/thougt appreciated
